C2G 2m USB 3.1 Gen 1 USB C to USB Micro B Cable - Black
Quicklinx: CHP3WS00 Mfr#: 88863
Length: 2m
£12.01 ex VAT
£14.41 inc VAT
This USB 3.0 (USB 3.1 Gen 1) USB-C to USB-Micro B cable is the perfect solution for connecting a smartphone, tablet, or other device that has a USB-Micro B port to a computer, tablet or other device that has a USB Type-C port up to 2 metres away for USB 3.0 (USB 3.1 Gen 1) communication. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 3.0 (USB 3.1 Gen 1) cable and differentiated from other cables which may support a different feature set. With its robust design, the USB-C connector can be plugged in and un-plugged up to 10,000 times; six times more than a standard USB A Connector. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. This cable supports a data rate up to 5Gbps for data transfer and sync with 5 volts and 1 amp of power for device operation and charging.
  • Lifetime warranty
    Length: 2.00 Meter
  • Warranty
    Lifetime
  • Colour
  • Length
    2 meter
C2G 2m USB 3.1 Gen 1 USB Type C to USB Micro B Cable - USB C Cable Black - USB-C cable - 2 m
USB-C cable
Sync and charge, colour-coded connectors, nickel plated shell
Length
2 m
Connector
24 pin USB-C - male
Connector (Second End)
10 pin Micro-USB Type B - male
USB 3.0/ USB 3.1
USB-C cable
American Wire Gauge (AWG)
24/30
Plated Connector
Gold
Length
2 m
Connector
24 pin USB-C - male
USB 3.0/ USB 3.1
Length: 2m
Brand: C2G
Price Range Ex VAT: 0 - 50
