Product
C2G 2m USB 2.0 USB-C to USB-Mini B Cable M/M - Black
Quicklinx: CHNRWS00 Mfr#: 88855
Length: 2m
£13.43 ex VAT
£16.11 inc VAT
This USB 2.0 USB-C to USB-Mini B cable is the perfect solution for connecting a camera, cellphone, tablet or other device that has a USB Mini B port to a computer, tablet or other device that has a USB Type-C port for USB 2.0 communication. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 2.0 cable and differentiated from other cables which may support a different feature set. The USB Type-C connector is smaller than traditional USB connector and features a symmetrical design which allows it to be easily connected on the first try. Additionally, the durability of the USB Type-C connector allows for up to 10,000 connection cycles. This cable supports a data rate up to 480Mbps for data transfer and sync with 5 volts and 1 amp of power for device operation and charging.
Note: This cable is designed to support USB 2.0 communication and features and is not able to support USB 3.1 Gen 2 Communication and features.
  • Warranty
    Lifetime
  • Colour
  • Length
    2 meter
C2G USB-C cable - 2 m
USB-C cable
Sync and charge, colour-coded connectors, nickel plated shell
Length
2 m
Connector
Mini-USB Type B - male
Connector (Second End)
24 pin USB-C - male
USB / USB 2.0
USB-C cable
American Wire Gauge (AWG)
24/30
Plated Connector
Gold
Length
2 m
Connector
24 pin USB-C - male
USB / USB 2.0
Length: 2m
Brand: C2G
Price Range Ex VAT: 0 - 50
