This USB 2.0 USB-C to USB-Micro B cable is the perfect solution for connecting a smartphone, tablet, or other device that has a USB-Micro B port to a computer, tablet or other device that has a USB Type-C port up to 2 metres away for USB 2.0 communication. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 2.0 cable and differentiated from other cables which may support a different feature set. With its robust design, the USB-C connector can be plugged in and un-plugged up to 10,000 times; six times more than a standard USB A Connector. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. This cable supports a data rate up to 480Mbps for data transfer and sync with 5 volts and 1 amp of power for device operation and charging Note: This cable is designed to support USB 2.0 communication and features and is not able to support USB 3.1 Gen 2 Communication and features.
Efficient charging and syncing
The 2m USB 2.0 USB Type-C to USB Micro-B Cable from C2G is designed to support both sync and charge functionality, making it a versatile choice for powering devices and transferring data at efficient speeds. -
Durable design
Featuring color-coded connectors, a nickel-plated shell, and a gold-plated connector, this USB-C cable is built for durability and a reliable connection every time. -
Universal compatibility
With a 24-pin USB-C connector on one end and a 5-pin Micro-USB Type-B on the other, this cable is compatible with a wide range of devices, ensuring you can connect to PCs and more without the need for multiple cables.
- C2G 2m USB 2.0 USB Type C to USB Micro B Cable M/M - USB C Cable Black - USB-C cable - Micro-USB Type B to 24 pin USB-C - 2 m
- USB-C cable
- Sync and charge, colour-coded connectors, nickel plated shell
- Length
- 2 m
- Connector
- 5 pin Micro-USB Type B - male
- Connector (Second End)
- 24 pin USB-C - male
- Black
- Limited lifetime warranty
- USB-C cable
- American Wire Gauge (AWG)
- 24/30
- Plated Connector
- Gold
- Length
- 2 m
- Black
- Connector
