This USB 2.0 USB-C to USB-B cable is the perfect solution for connecting a printer, hub, or other device that has a USB B port to a computer, tablet or other device that has a USB Type-C port up to 2 metres away for USB 2.0 communication. This cable supports a data rate up to 480Mbps for data transfer and sync with 5 volts and 1 amp of power for device operation and charging. With its robust design, the USB-C connector can be plugged in and un-plugged up to 10,000 times; six times more than a standard USB A Connector. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 2.0 cable and differentiated from other cables which may support a different feature set. This cable is designed to support USB 2.0 communication and features and is not able to support USB 3.1 Gen 2 communication and features.
Efficient charging and syncing
The 2m USB 2.0 USB Type C to USB B Cable M/M facilitates quick and efficient charging alongside seamless data syncing capabilities. Its design incorporates color-coded connectors and a nickel-plated shell, ensuring both durability and ease of use. -
High-quality connection
Featuring a gold-plated connector that resists corrosion, this USB C Cable Black provides a reliable connection between devices. The double-shielded technology further enhances signal integrity, making it ideal for both professional and personal use. -
Versatile compatibility
Designed to connect a wide range of devices, this cable supports seamless connectivity from USB-C equipped devices to USB-B devices. Its compatibility with PC systems allows for a broad usage spectrum, from office workstations to home entertainment setups.
- C2G 2m USB 2.0 USB Type C to USB B Cable M/M - USB C Cable Black - USB-C cable - USB Type B to 24 pin USB-C - 2 m
- USB-C cable
- Technology
- Double shielded
- Sync and charge, colour-coded connectors, nickel plated shell
- Length
- 2 m
- Connector
- 4 pin USB Type B - male
- Connector (Second End)
- 24 pin USB-C - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB-C cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 24/30
- Plated Connector
- Gold
- Length
- 2 m
- Black
- Connector
- USB / USB 2.0
