Connect to mobile phones, GPS systems, PDAs, OTG devices and digital cameras by using the micro-USB connection on your computer or other USB device. The micro-USB connector is smaller and thinner than the previous USB Mini-b standard while offering better performance. Its small form factor is ideal for today's compact portable devices while easily transferring data or charging your device at a transfer speed up to 480 Mbps. This cable is compliant with USB 2.0 specifications and the on-the-go supplement.
- C2G USB 2.0 A to Micro B Cable - USB cable - USB to Micro-USB Type B - 2 m
- USB cable
- Ferrite bead
- Length
- 2 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 5 pin Micro-USB Type B - male
- USB 2.0 On-The-Go
- Black
- Limited lifetime warranty
- USB cable
- Ferrite bead
- Length
- 2 m
- Black
- Connector
- USB 2.0 On-The-Go
