This USB A/B cable from C2G is designed to connect from the USB port on your hub, PC or Mac to your USB device. This fully-rated USB cable provides transfer rates up to 480 Mbps, and easily attaches to any USB device. Compatible with USB 1.0, 1.1 and 2.0.
 - C2G - USB cable - USB to USB Type B - 2 m
 - USB cable
- Technology
 - Double shielded twisted pair
- Length
 - 2 m
- Connector
 - 4 pin USB Type A - male
- Connector (Second End)
 - 4 pin USB Type B - male
 - USB / USB 2.0
 - White
 - USB cable
- Technology
- Length
 - 2 m
 - White
- Connector
 - USB / USB 2.0, Plug and Play, UL, RoHS
