C2G 2m USB 2.0 A/B Cable - White
Quicklinx: 63M9WS00 Mfr#: 81561
Select:
This USB A/B cable from C2G is designed to connect from the USB port on your hub, PC or Mac to your USB device. This fully-rated USB cable provides transfer rates up to 480 Mbps, and easily attaches to any USB device. Compatible with USB 1.0, 1.1 and 2.0.
C2G - USB cable - USB to USB Type B - 2 m
USB cable
Double shielded twisted pair
Length
2 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type B - male
USB / USB 2.0
White
USB cable
Length
2 m
White
Connector
USB / USB 2.0, Plug and Play, UL, RoHS
