This OM3 Duplex Multimode Fibre Optic Cable is ideal for connecting 10GBase-SR, 10GBase-LRM, SFP+ and QSFP+ transceivers for 10 gigabit network connections. This cable has a LSZH jacket which protects from toxic and corrosive gases in poorly ventilated spaces and other areas where it is most critical. This cable also provides backward compatibility with existing 50/125 equipment and the performance headroom required to support LED and VCSEL laser light sources, and 10 Gigabit Ethernet applications. The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures.
High compatibility
Designed to seamlessly integrate with PC systems, this ST-ST 10Gb 50/125 OM3 Duplex Multimode PVC Fiber Optic Cable ensures a reliable connection for high-speed data transfer. -
Enhanced safety
Featuring a Low Smoke Zero Halogen (LSZH) jacket, this cable minimizes the amount of toxic and corrosive gas emitted during combustion, making it a safer choice for your networking needs. -
Optimal performance
With a core and cladding diameter of 50 / 125 micron, this cable is engineered for superior performance, supporting data transmission rates of 10Gb across multimode fiber optics technology.
- C2G ST-ST 10Gb 50/125 OM3 Duplex Multimode PVC Fiber Optic Cable (LSZH) - network cable - 2 m - aqua
- Network cable - OM3
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Multimode
- Halogen-free
- Length
- 2 m
- Core / Cladding Diameter
- 50 / 125 micron
- Connector
- 2 x ST multi-mode - male
- Connector (Second End)
- Aqua
- Limited lifetime warranty
- Network Cable Type
- Technology
- Multimode
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- Fibre Qty
- 2
- 50 / 125 micron
- Halogen-free
- Length
- 2 m
- Aqua
- Connector
- TIA/EIA-455-171A
- -20 °C
- 70 °C
