C2G 2m Select High Speed HDMI with Ethernet
Quicklinx: 915JWS00 Mfr#: 80553
Type: HDMI
Length: 2m
£4.96 ex VAT
£5.95 inc VAT
Experience ULTRA HD (4K) displays with this Select High-Speed HDMI Cable which provides a fast and reliable connection for home theatre or desktop audio video applications requiring high speed HDMI capabilities and video resolutions up to 4K (2160p). This High-Speed HDMI Cable supports the latest HDMI features including Ultra HD, 4K at 50/60 (2160p), up to 32 audio channels and wide angle theatrical 21:9 video aspect ratio and is compatible with any modern Laptop, Chromebook, HDTV or gaming console, including Sony PlayStation 4 (PS4) and Microsoft Xbox ONE. The cable is also backwards compatible with PlayStation 3 (PS3) and Xbox 360. The CL2 rated cable jacket is designed to meet the requirements for in-wall installations. The Ethernet capabilities of the cable allow users to connect multiple Ethernet-enabled HDMI devices through a single Ethernet connection. This fully-functional, high bandwidth cable is tested to perform at industry standards and is backed by a lifetime warranty. Note: Both the source device and display must support a HDMI feature in order to pass that particular feature through this cable.
  • High-quality connectivity
    The 2m Select High Speed HDMI Cable with Ethernet - 4K - UltraHD by C2G is designed with a 28 American Wire Gauge (AWG) and 100 ohm impedance, ensuring reliable, high-quality connectivity for all your audio and video needs.
  • Durable design
    Featuring a robust PVC jacket and aluminum foil with braid shielding, this HDMI cable is built to withstand the rigors of frequent use while minimizing signal interference, ensuring a clear, uninterrupted viewing experience.
  • Enhanced viewing experience
    With support for HDMI interface, this cable is capable of delivering 4K UltraHD resolution, bringing a stunning visual experience to your home theater or gaming setup.
C2G 2m Select High Speed HDMI Cable with Ethernet - 4K - UltraHD - HDMI cable with Ethernet - 2 m
Cable
Shielded
28
Length
2 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
Cable Type
Shielded
28
Jacket Material
PVC
Shielding Material
Aluminium foil with braid
Impedance
100 Ohm
Length
2 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
UL
Limited warranty - lifetime
Type: HDMI
Length: 2m
Brand: C2G
