Premium HD15 to 5-BNC video cables from C2G are constructed with premium quality 75-Ohm mini coax wire to ensure a crisp monitor image. They are designed to work with monitors, HDTV and other video applications. Low-loss 75-Ohm copper wire and polyethylene dielectric provide accurate picture resolution and color.
- C2G Premium VGA cable - 2 m
- VGA cable
- Technology
- Double shielded coaxial
- Molded, colour-coded connectors, copper centre conductor
- Length
- 2 m
- Connector
- HD-15 - male
- Connector (Second End)
- 5 x BNC - male
- UL 2919, FCC, RoHS
- VGA cable
- Technology
- Shielding Material
- Aluminum mylar foil with copper braid
- American Wire Gauge (AWG)
- 28
- Length
- 2 m
- Connector
- 15 pin HD D-Sub (HD-15) - male
- 5 x BNC - male
