This adapter cable is an ideal solution for connecting the Mini DisplayPort output of a small laptop or tablet to a computer monitor which accepts a DisplayPort input. This cable carries a digital audio/video signal and supports up to a 4k resolution. Built to DisplayPort 1.2 standards, this cable meets the requirements of high performance applications.
Resolution Support
Supports up to 4K resolution -
DisplayPort Specification
DisplayPort 1.2 Standards -
Cable Colour
- C2G 2m Mini DisplayPort to DisplayPort Adapter Cable 4K UHD - Black - DisplayPort cable - 2 m
- DisplayPort cable
- Length
- 2 m
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- DisplayPort - male
- Black
- Limited lifetime warranty
- DisplayPort cable
- Length
- 2 m
- Black
- Connector
- 20 pin DisplayPort - male
- DisplayPort 1.2
