C2G 2m Mini DisplayPort Cable M/M - White
Quicklinx: 9MSDWS00 Mfr#: 84411
Select:
  • 2m
This cable is an ideal solution for connecting the Mini DisplayPort output of a small laptop or tablet to a computer monitor which accepts a Mini DisplayPort input. This cable carries a digital audio/video signal. Support of a High Bit Rate (HBR) bandwidth means that this cable can carry up to a 4k resolution. Built to DisplayPort 1.2 standards, this cable meets the requirements of high performance applications.
  • High compatibility
    Designed specifically for PCs, this 2m Mini DisplayPort Cable 4K UHD M/M - White ensures seamless connectivity and integration with a wide range of PC systems, making it a versatile choice for various setups
  • Superior connectivity
    Featuring male Mini DisplayPort connectors on both ends, this cable provides a secure and stable connection between devices, supporting DisplayPort 1.2 standards for high-quality video transmission without compromise
C2G 2m Mini DisplayPort Cable 4K UHD M/M - White - DisplayPort cable - 2 m
DisplayPort cable
Length
2 m
Connector
Mini DisplayPort - male
Connector (Second End)
White
DisplayPort cable
Length
2 m
White
Connector
DisplayPort 1.2
