With LC to LC termination, this high quality fibre optic patch cable is specifically designed for Fast Ethernet, fibre channel, ATM and Gigabit Ethernet applications. The small LC connectors satisfy the need for higher port density both in the telecom room and the work area, and offer twice the port density of traditional SC and ST fibre connectors. The LC connector with its RJ-style latch clip design is easy to engage and disengage, and gives each connection greater durability in resisting pulls, strains, snags, and impacts during cabling installs and maintenance. The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures. This reduces the amount of harmful toxic and corrosive gases that cabling made with plastic materials would otherwise emit into the air during combustion. This construction makes LSZH cables ideal for use where the protection of people and equipment from harmful corrosive gases is absolutely critical. The patented injection moulding process provides each connection greater durability in resisting pulls, strains and impacts from cabling installs.
Enhanced safety
The Low-Smoke Zero-Halogen (LSZH) jacket material significantly reduces the amount of toxic and corrosive gas emitted during combustion. This makes the C2G Low-Smoke Zero-Halogen patch cable a safer choice for enclosed spaces. -
High-quality connectivity
Featuring a core and cladding diameter of 62.5 / 125 micron, this cable ensures high-quality, reliable connections with reduced signal loss, making it ideal for network applications. -
Durable design
Equipped with male LC multi-mode connectors on both ends, the cable is designed for durability and a secure connection, ensuring consistent performance and longevity.
- C2G Low-Smoke Zero-Halogen - patch cable - 2 m - orange
- Patch cable
- Technology
- Fibre optic
- Type of Fibre Optics
- Multimode
- Length
- 2 m
- Core / Cladding Diameter
- 62.5 / 125 micron
- Connector
- 2 x LC multi-mode - male
- Connector (Second End)
- Orange
- Limited lifetime warranty
- Network Cable Type
- Patch cable
- Technology
- Fibre optic
- Multimode
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- Fibre Qty
- 2
- 62.5 / 125 micron
- Length
- 2 m
- Orange
- Connector
- RoHS
