The FlexUSB A/A Extension cable from C2G not only extends the length of your existing USB A/B cable, it is the world's first USB A/A cable with a flexible connector! FlexUSB cables have patent-pending FlexConnex technology, allowing USB cables to be used in difficult-to-reach and confined spaces. Stop worrying about inconvenient locations or awkward orientations of your USB ports. With horizontal and vertical hinges on the USB A connector, you can connect your USB devices in the position most convenient for you.
- C2G FlexUSB USB extension cable - USB to USB
- USB extension cable
- 180° rotation
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 4 pin USB Type A - female
- USB / USB 2.0
- 180° rotation
- Connector
- USB / USB 2.0, RoHS
