eSATA provides more performance than existing solutions and is hot-pluggable. You can now utilize shielded cable lengths up to 2 meters outside the desktop PC to take advantage of the benefits the SATA interface brings to storage.
SATA is now out-of-the-box as an external standard, with specifically defined cables, connectors, and signal requirements. With eSATA, you get a robust and user-friendly external connection with high performance and cost-effective expansion storage. SATA 3.0 compatible with transfer rates up to 6 Gbps!
- C2G eSATA cable - 2 m
- eSATA cable
- Interface Speed
- Serial ATA 150/300/600
- Technology
- Shielded
- Length
- 2 m
- Connector
- 7 pin external Serial ATA - male
- Connector (Second End)
- Black
- Limited lifetime warranty
- Storage Cable Type
- eSATA cable
- Interface Speed
- Technology
- Shielded
- Length
- 2 m
- Black
- Connector
