C2G 2m European Non-Polarised Power Cord CEE 7/7 - IEC 60320 C7
Quicklinx: 98PRWS00 Mfr#: 80617
Length: 2m
£5.83 ex VAT
£6.99 inc VAT
Replace your overused or misplaced power cable, or just get some extra cords for convenience. This non-polarized power cord is designed to work with laptops, gaming consoles and other audio/video equipment that uses a 2-slot non-polarized power cord. Plus this heavy duty 18 AWG cord features a fully melded design for maximum durability and long life. The female connector, often called a figure of 8, plugs directly into the device while the male connector plugs into a standard power outlet.
  • Versatile compatibility
    Designed to power a wide range of PCs, this power cord seamlessly integrates with most computer setups, ensuring a reliable power connection.
  • Durable design
    Featuring an 18 AWG rating, this power cable is built for durability and long-term use, providing a dependable solution for powering your devices.
  • Secure connections
    Equipped with a power IEC 60320 C7 connector on one end and a power CEE 7/7 male connector on the other, it offers secure and stable connections, minimizing the risk of disconnection.
C2G Non-Polarised Power Cord - power cable - power IEC 60320 C7 to power CEE 7/7 - 2 m
Power cable
Molded
Length
2 m
Connector
Power IEC 60320 C7
Connector (Second End)
Power CEE 7/7 - male
Rated Voltage
AC 250 V
Power cable
American Wire Gauge (AWG)
18
Rated Voltage
AC 250 V
Molded
Length
2 m
Connector
Power IEC 60320 C7
Length: 2m
Brand: C2G
