This adapter cable is an ideal solution for connecting the DisplayPort output of a laptop to a computer monitor which accepts a DVI-D input. This cable carries a digital video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
Seamless connectivity
Designed for optimal performance, the 2m DisplayPort to Single Link DVI-D Adapter Cable M/M ensures a seamless connection between your DisplayPort-equipped PC and DVI-D enabled display. This cable supports high-definition video transmission, making it suitable for professional presentations, video editing, and gaming. -
Durable design
Featuring robust PVC shielding and an American Wire Gauge (AWG) of 30, this cable is built to withstand daily use while maintaining signal integrity. The shielded technology minimizes interference, ensuring a clear, reliable signal at all times.
 - C2G 2m DisplayPort to Single Link DVI-D Adapter Cable M/M - DP to DVI - Black - DisplayPort cable - 2 m
 - DisplayPort cable
- Technology
 - Shielded
- Length
 - 2 m
- Connector
 - DisplayPort - male
- Connector (Second End)
 - DVI-D - male
 - Black
 - Limited lifetime warranty
 - DisplayPort cable
- Technology
 - Shielded
- Shielding Material
 - PVC
- American Wire Gauge (AWG)
 - 30
- Length
 - 2 m
 - Black
- Connector
 - 20 pin DisplayPort - male
 - 18+1 pin digital DVI (Single-Link) - male
