C2G 2m DisplayPort Cable with Latches M/M - Black
Quicklinx: 9MS4WS00 Mfr#: 84401
Length: 2m
41 In Stock
£11.88 ex VAT
£14.25 inc VAT
This cable is an ideal solution for connecting the DisplayPort output of a laptop to a computer monitor which accepts a DisplayPort input. This cable carries a digital audio/video signal and the connectors feature latches which secure the cable in the port. Support of a High Bit Rate (HBR) bandwidth means that this cable can carry up to a 4k resolution. Built to DisplayPort 1.2 standards, this cable meets the requirements of high performance applications.
  • Enhanced connectivity
    The 2 m DisplayPort Cable with Latches 8K UHD M/M - 4K - Black by C2G offers a reliable connection between your devices, featuring a 20 pin DisplayPort on both ends. The male connectors ensure a secure link to prevent accidental disconnections, enhancing your viewing or gaming experience without interruption.
  • High-quality signal transmission
    Constructed with an American Wire Gauge (AWG) of 32 and double-shielded with aluminum foil and braid, this cable supports high-quality signal transmission. Its compliance with DisplayPort 1.2 standards supports resolutions up to 8K UHD, making it suitable for high-definition audio and video applications.
  • Durable design
    The durable design of this DisplayPort cable is evident in its robust construction. The shielding material not only protects against external interference but also ensures longevity, making it a reliable choice for everyday use.
C2G 2m DisplayPort Cable with Latches 8K UHD M/M - 4K - Black - DisplayPort cable - 2 m
DisplayPort cable
Double shielded
Latched
Length
2 m
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - male
DisplayPort cable
Double shielded
Shielding Material
Aluminium foil with braid
32
Latched
Length
2 m
Connector
20 pin DisplayPort - male
DisplayPort 1.2
Length: 2m
Brand: C2G
