C2G 2m Cat6 550 MHz Snagless Patch Cable - Purple
Quicklinx: 6BV4WS00 Mfr#: 83633
For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
  • High-speed connectivity
    Experience seamless network performance with the Cat6 Booted Unshielded (UTP) Network Patch Cable, designed to support tested frequencies up to 550 MHz. This ensures optimal performance for bandwidth-intensive applications, making it an ideal choice for both home and office environments.
  • Durable design
    Constructed with a 24 American Wire Gauge (AWG) and a robust PVC jacket, this patch cable is built to last. The gold-plated RJ-45 connectors provide a secure and corrosion-resistant connection, ensuring long-term reliability and signal integrity.
  • Universal compatibility
    Featuring a T568B wiring scheme and compatibility with PCs, this network patch cable offers a versatile solution for connecting a wide range of devices. Its male RJ-45 connectors on both ends make it easy to connect routers, switches, and other network components.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 2 m - purple
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
2 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Purple
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
24
Plated Connector
Gold
Length
2 m
Purple
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
