C2G 2m Cat5E 350 MHz Snagless Patch Cable - Black
Quicklinx: 6BM3WS00 Mfr#: 83183
For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
  • Enhanced connectivity
    The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G is designed with high-quality 24 AWG wires, ensuring reliable connectivity and improved network performance. Its gold-plated RJ-45 connectors provide a secure, corrosion-resistant connection for uninterrupted service.
  • Durable design
    Featuring a robust PVC jacket material, this network patch cable is built to withstand the rigors of daily use, maintaining its integrity and performance over time. The boot cover adds extra strain relief that protects the plug and the connection from damage.
  • Versatile compatibility
    With its T568B wiring scheme and compatibility with PC systems, this patch cable seamlessly integrates into any existing network setup, making it a versatile choice for various applications, from home networks to large data centers.
C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 2 m - black
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded
Length
2 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
2 m
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
