For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
Enhanced connectivity
The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G is designed with high-quality 24 American Wire Gauge (AWG) copper wires, ensuring reliable connectivity and improved signal integrity for your network. With a durable PVC jacket, this cable is built to withstand rigorous everyday use while maintaining optimal performance. -
High-speed performance
Featuring a tested frequency of up to 350 MHz, this patch cable supports fast data transfer rates, making it suitable for a wide range of applications, from home networks to data centers. Its T568B wiring scheme and gold-plated RJ-45 connectors provide a secure, corrosion-resistant connection for uninterrupted service. -
Universal compatibility
Designed to meet the RoHS compliance standards, this network patch cable is compatible with PCs and a broad range of devices. Its universal design ensures seamless integration with existing network infrastructure, making it a versatile solution for various networking requirements.
- C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 2 m - grey
- Patch cable - CAT 5e
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Molded, snagless, stranded
- Length
- 2 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Grey
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 2 m
- Grey
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 350 MHz
