C2G 2m Cat5E 350 MHz Snagless Booted Patch Cable - Grey
Quicklinx: 69N5WS00 Mfr#: 83143
For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
  • Enhanced connectivity
    The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G is designed with high-quality 24 American Wire Gauge (AWG) copper wires, ensuring reliable connectivity and improved signal integrity for your network. With a durable PVC jacket, this cable is built to withstand rigorous everyday use while maintaining optimal performance.
  • High-speed performance
    Featuring a tested frequency of up to 350 MHz, this patch cable supports fast data transfer rates, making it suitable for a wide range of applications, from home networks to data centers. Its T568B wiring scheme and gold-plated RJ-45 connectors provide a secure, corrosion-resistant connection for uninterrupted service.
  • Universal compatibility
    Designed to meet the RoHS compliance standards, this network patch cable is compatible with PCs and a broad range of devices. Its universal design ensures seamless integration with existing network infrastructure, making it a versatile solution for various networking requirements.
C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 2 m - grey
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded
Length
2 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
2 m
Grey
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
