C2G 2m Cat5E 350 MHz Snagless Booted Patch Cable - Green
Quicklinx: 69NMWS00 Mfr#: 83203
For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
  • High-quality connectivity
    Featuring a high-grade PVC jacket and 24 AWG American Wire Gauge construction, this Cat5e Booted Unshielded (UTP) Network Patch Cable ensures durable and reliable connectivity for all your networking needs. The gold-plated RJ-45 connectors provide a secure connection, minimizing interference and maximizing signal quality.
  • Enhanced performance
    Designed to support a tested frequency of up to 350 MHz, this patch cable is perfect for high-speed data transmission. The T568B wiring scheme and UTP technology work together to reduce noise and crosstalk, ensuring fast and stable network performance.
  • Universal compatibility
    With its RJ-45 male connectors, this network patch cable is compatible with a wide range of devices. Whether connecting PCs, servers, printers, or switches, this cable provides a dependable solution for all your networking requirements.
C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 2 m - green
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded
Length
2 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Green
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
2 m
Green
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
