This power cord is the ideal solution for powering a network device or connecting to a PDU in a data centre or network wiring closet. This cable is able to support up to 250 volt connections and features 1.00mm² conductor construction. The fully moulded design provides for maximum durability and long life.
Enhanced compatibility
Designed specifically for PCs, this power extension cable seamlessly integrates with your existing setup, ensuring a reliable connection that enhances your system's performance. -
Robust construction
Featuring a durable design rated for AC 250 V, this cable is built to withstand the demands of continuous use, providing a dependable power solution for your computing needs.
 - C2G 250 Volt Hot Condition Power Cord Extension - power extension cable - IEC 60320 C15 to IEC 60320 C14 - 2 m
 - Power extension cable
 - Molded
- Length
 - 2 m
- Connector
 - Power IEC 60320 C15
- Connector (Second End)
 - Power IEC 60320 C14
- Rated Voltage
 - AC 250 V
 - Black
 - Limited lifetime warranty
- Rated Voltage
 - AC 250 V
 - Molded
- Length
 - 2 m
 - Black
- Connector
