C2G 250 Volt Hot Condition Power Cord Extension
Quicklinx: CZVZWS00 Mfr#: 80634
This power cord is the ideal solution for powering a network device or connecting to a PDU in a data centre or network wiring closet. This cable is able to support up to 250 volt connections and features 1.00mm² conductor construction. The fully moulded design provides for maximum durability and long life.
  • Enhanced compatibility
    Designed specifically for PCs, this power extension cable seamlessly integrates with your existing setup, ensuring a reliable connection that enhances your system's performance.
  • Robust construction
    Featuring a durable design rated for AC 250 V, this cable is built to withstand the demands of continuous use, providing a dependable power solution for your computing needs.
C2G 250 Volt Hot Condition Power Cord Extension - power extension cable - IEC 60320 C15 to IEC 60320 C14 - 2 m
Power extension cable
Molded
Length
2 m
Connector
Power IEC 60320 C15
Connector (Second End)
Power IEC 60320 C14
Rated Voltage
AC 250 V
Rated Voltage
AC 250 V
Molded
Length
2 m
Connector
Power IEC 60320 C15
Power IEC 60320 C14
