C2G 23m Active Optical DisplayPort Cable CMP
Quicklinx: DWMLWS00 Mfr#: 82398
Select:
The DisplayPort AOC is the perfect solution for extending DisplayPort signals in classrooms, conference rooms, healthcare facilities, digital signage and other commercial environments. [B]Convenience[/B].
Utilising AOC technology that performs similar to traditional copper cabling, the optical fibre construction between the connectors provides optimum performance and easy installation. The AOC technology delivers several advantages which make it a smart choice in select installations. The cable diametre is smaller than copper and more flexible, making it easier to install in tight spaces. Constructed from fibre strands, this cable reduces the risk of EMI/RFI so performance is stable when used in typically high interference environments such as data centres, surgical theatres, or manufacturing facilities where high resolution and consistent display are critical.
[B]Performance[/B].
The AOC draws power from the DisplayPort source device, so no external power source is required. In addition to low power consumption, these cables are also plug and play and hot swappable. Additionally, the DisplayPort Active Optical Cable supports the latest 4K60 content delivery over longer distances.
  • Colour
    Grey
  • Warranty
    3 years
  • Connector 1
    DisplayPort Male
  • Connector 2
    DisplayPort Male
C2G 23m DisplayPort Active Optical Cable (AOC) - 4K UHD - Plenum CMP-Rated - DisplayPort cable - 23 m
Cable
DisplayPort cable
Fibre optic
Length
23 m
Grey
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - male
DisplayPort 1.2
Plenum, 4K support
3-year warranty
Cable Type
DisplayPort cable plenum, 4K support
Fibre optic
Jacket Material
PVC
DisplayPort 1.2
Length
23 m
Active Optical Cable (AOC), EMI/RFI protection, 60+ Hz refresh rate
Grey
Connector
20 pin DisplayPort - male
CEC, RoHS 2011/65/EU, EDID compatible, HDCP 1.3, CMP-OF-FT6, UL CMP-OF
415 g
Limited warranty - 3 years
