The new Pro Series commercial grade CL2 cables offer true digital performance while meeting the highest standards in building code requirements for in-wall installations. Available for HDMI, DVI and DVI+3.5mm audio signals, these cables can meet the demands of virtually any commercial installation.
By supporting resolutions of 1080p for displays and up to 1920 x 1200 pixels for computers, and with lengths ranging from 7.6m to 30.4m, the Pro Series is the ideal connectivity solution for A/V equipment used in classrooms or conference rooms. 24k gold-plated connectors prevent metal corrosion, resulting in the optimal signal transfer for the highest picture and sound quality. Shielded 24AWG copper conductors protect against EMI and RFI to ensure uninterrupted performance. High quality materials and construction, along with rigorous factory testing, guarantee long-term, dependable performance.
High-quality connectivity
Featuring 24 AWG American Wire Gauge for robust signal transmission, this DVI cable ensures a reliable connection between devices. Its shielded design minimizes interference, delivering a clear, uninterrupted signal for your PC. -
Gold-plated durability
The gold-plated connectors on both ends of the cable not only provide superior signal quality but also offer enhanced durability. This design ensures a long-lasting, corrosion-resistant connection that maintains the integrity of your video signal. -
Versatile compatibility
Designed to support digital video signals, this cable is equipped with 18+1 pin digital DVI (Single-Link) connectors, making it compatible with a wide range of PC video interfaces. Its compliance with RoHS standards further ensures a safe and environmentally friendly product.
- C2G Pro Series DVI cable - 22.8 m
- DVI cable
- Technology
- Shielded
- Length
- 22.8 m
- Connector
- DVI-D - male
- Connector (Second End)
- DVI-D - male
- RoHS
- Black
- Limited lifetime warranty
- DVI cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 24
- Plated Connector
- Gold
- Length
- 22.8 m
- Black
- Connector
- 18+1 pin digital DVI (Single-Link) - male
- RoHS
