Brand
C2G 20m DB25 M/F Extension Cable
Quicklinx: 682NWS00 Mfr#: 81403
Easily extend your cables at a lower cost than buying a new cable. All 25 lines are wired straight through pin-to-pin for ease of compatibility. Each cable is foil shielded for EMI/RFI protection, and is available fully snagless with thumbscrew connectors for a fast, easy connection every time.
  • Warranty Details
    This product carries a lifetime warranty
  • Product Colour
    Beige
C2G Extension Cable - serial / parallel extension cable - DB-25 to DB-25 - 20 m
Serial / parallel extension cable
Shielded
Molded, thumbscrews
Length
20 m
Connector
25 pin D-Sub (DB-25) - male
Connector (Second End)
25 pin D-Sub (DB-25) - female
Shielded
Molded, thumbscrews
Length
20 m
Connector
RoHS
