For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
High-speed connectivity
Experience seamless network performance with the Cat6 Booted Unshielded (UTP) Network Patch Cable, designed to support tested frequencies up to 550 MHz. This ensures high-speed data transmission for your computing needs, making it an ideal choice for both home and office environments. -
Durable design
Constructed with a 24 American Wire Gauge (AWG) and a robust PVC jacket, this patch cable is built to last. The gold-plated RJ-45 connectors provide a reliable connection and resist corrosion, ensuring long-term performance without compromise. -
Universal compatibility
Featuring a T568B wiring scheme and compatible with PC systems, this network patch cable offers a versatile solution for connecting a wide range of devices. Whether you're setting up a new network or upgrading an existing one, its universal compatibility ensures a hassle-free integration.
- C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 20 m - grey
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Molded, snagless, stranded
- Length
- 20 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Grey
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Plated Connector
- Gold
- Length
- 20 m
- Grey
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 550 MHz
