C2G 20m Cat6 550 MHz Snagless Patch Cable - Blue
Quicklinx: 6BQ1WS00 Mfr#: 83394
For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
  • High-speed connectivity
    Experience seamless network performance with the Cat6 Booted Unshielded (UTP) Network Patch Cable, designed to support tested frequencies up to 550 MHz. This ensures optimal performance for your networking needs, making it a suitable solution for high-speed Internet, file transfers, and video streaming.
  • Durable design
    Constructed with a 24 American Wire Gauge (AWG) and a robust PVC jacket, this patch cable is built to last. The gold-plated RJ-45 connectors provide a secure and corrosion-resistant connection, ensuring long-term reliability and maintaining signal integrity.
  • Universal compatibility
    Designed to meet the T568B wiring scheme and compliant with RoHS standards, this network patch cable offers broad compatibility with PCs and network devices. Its versatile design ensures it can be integrated into virtually any network setup with ease.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 20 m - blue
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
20 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
24
Plated Connector
Gold
Length
20 m
Blue
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
