C2G 20ft 4K HDMI Cable with Ethernet
Quicklinx: GM2QWS00 Mfr#: 50188
Length: 6.07m
£50.58 ex VAT
£60.69 inc VAT
The C2G Performance Series Premium High Speed HDMI Cable supports all HDMI 2.0 features and has been tested to conform with the Premium HDMI Cable Certification Program for highest performance and ultra-reliability. This cable is ideal for HD Blu-ray and HD DVD video, experiencing resolutions up to 4k (4096 x 2160) at 60Hz, bandwidths up to 18Gbps, HDR for higher contrast ratios and vivid colors, plus 32 uncompressed digital audio channels to provide crystal-clear sound - perfect for home theater applications or digital signage.
This Premium High Speed HDMI Cable was designed to exceed the highest measure of HDMI performance and will enhance video experiences with higher resolutions, increased speeds, and sharper images. They include integrated finger grips on the top, bottom, and sides, for easy insertion and removal, and the gripping connector shell has 2x greater port retention to keep your devices connected. The gold plated connectors on the cable allow for better shielding, increased electrical conductivity, and durability.
This Premium High Speed HDMI Cable has been tested to deliver the full 18Gbps bandwidth required by the specifications for Premium High Speed HDMI certification. The cable also supports the updated library of Consumer Electronic Control (CEC) commands, allowing communication between devices connected through the HDMI ports. Lastly, this fully-functional, high bandwidth cable is backed by a lifetime warranty.
  • Colour
  • Warranty
    Lifetime
  • Connector 1 :
    (1) HDMI Male
  • Connector 2 :
    (1) HDMI Male
C2G 20ft 4K HDMI Cable with Ethernet - Premium Certified - High Speed 60Hz - HDMI cable with Ethernet - HDMI / audio - 6.07 m
Cable
Shielded
American Wire Gauge (AWG)
30
Length
6.07 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
4K support
Cable Type
HDMI cable with Ethernet 4K support
Interface Supported
HDMI / audio
Shielded
30
Jacket Material
PVC
Shielding Material
Aluminium mylar
Length
6.07 m
Audio Return Channel (ARC), Dolby TrueHD support, Dolby DTS-HD Master Audio support, Dolby Digital Plus, 32 audio channels, 2 video streams (Dual View)
Connector
19 pin HDMI Type A - male
RoHS 2011/65/EU
740 g
Limited warranty - lifetime
Length: 6.07m
Brand: C2G
