This adapter converter is an ideal solution for adapting the Mini DisplayPort output of a small laptop or tablet so that it may be connected to a monitor which accepts a DVI-D input. This adapter converter carries a digital video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
- C2G 20cm Mini DisplayPort to DVI Adapter - Thunderbolt to Single Link DVI-D Converter M/F - White - DisplayPort cable - 20 cm
- DisplayPort cable
- Length
- 20 cm
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- DVI-D - female
- White
- 3-year warranty
- DisplayPort cable
- Length
- 20 cm
- White
- Connector
- 18+1 pin digital DVI (Single-Link) - female
- 3-year warranty
