C2G 20cm Mini DisplayPort Male to Single Link DVI-D Female Adapter Cable - White
Quicklinx: 9MSNWS00 Mfr#: 84312
Length: 20cm
Colours:
£10.88 ex VAT
£13.05 inc VAT
This adapter converter is an ideal solution for adapting the Mini DisplayPort output of a small laptop or tablet so that it may be connected to a monitor which accepts a DVI-D input. This adapter converter carries a digital video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
  • Resolution Support
    1920 X 1200
  • Cable Colour
    White
C2G 20cm Mini DisplayPort to DVI Adapter - Thunderbolt to Single Link DVI-D Converter M/F - White - DisplayPort cable - 20 cm
DisplayPort cable
Length
20 cm
Connector
Mini DisplayPort - male
Connector (Second End)
DVI-D - female
White
3-year warranty
DisplayPort cable
Length
20 cm
White
Connector
18+1 pin digital DVI (Single-Link) - female
3-year warranty
Length: 20cm
Brand: C2G
Price Range Ex VAT: 0 - 50
