This adapter converter is an ideal solution for adapting the DisplayPort output of a laptop so that it may be connected to a computer monitor which accepts a DVI-D input. This adapter carries a digital video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
- C2G DisplayPort Male to Single Link DVI-D Female Adapter Converter - video adapter - 20 cm
- Video adapter
- Latched
- Length
- 20 cm
- Connector
- DisplayPort - male
- Connector (Second End)
- DVI-D - female
- Black
- 3 years warranty
- Video adapter
- Latched
- Length
- 20 cm
- Black
- Connector
- 20 pin DisplayPort - male
- 18+1 pin digital DVI (Single-Link) - female
- 3 years warranty
