C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black
Quicklinx: 9MSVWS00 Mfr#: 84322
Length: 20cm
38 in stock
£18.82 ex VAT
£22.58 inc VAT
This adapter converter is an ideal solution for adapting the DisplayPort output of a laptop so that it may be connected to a HDTV or projector which accepts a HDMI input. This adapter converter carries a digital audio/video signal, supports up to a 1080p resolution and meets the requirement of high performance applications.
  • Resolution Support
    1080p
  • Cable Colour
C2G 20cm DisplayPort to HDMI Adapter - DP Male to HDMI Female - Black - DisplayPort cable - 20 cm
DisplayPort cable
Length
20 cm
Connector
DisplayPort - male
Connector (Second End)
HDMI - female
DisplayPort cable
Shielding Material
American Wire Gauge (AWG)
30
Length
20 cm
Connector
20 pin DisplayPort - male
19 pin HDMI Type A - female
Length: 20cm
Brand: C2G
Stock Status: In stock
