Your basket is empty
C2G 20cm DisplayPort™ 1.1 Male to HD15 VGA Female Adapter Cable
Quicklinx: 801QWS00 Mfr#: 81276
This adapter converts a DisplayPort signal for viewing on a VGA-equipped display. Connect the adapter directly to the PC. Then use your VGA cable between the adapter and the display, and enjoy PC video content on virtually any VGA display. Features 20cm dongle-style adapter, nickel-plated DisplayPort connector, molded VGA connector, 28 AWG copper wire, Aluminum shielding to protect against EMI/RFI.
C2G DisplayPort 1.1 to VGA Adapter Cable - VGA adapter - 20 cm
VGA adapter
Shielded
Molded
Length
20 cm
Connector
DisplayPort - male
Connector (Second End)
HD-15 - female
VGA adapter
Shielded
Shielding Material
Aluminium foil
American Wire Gauge (AWG)
30
Plated Connector
Nickel
Molded
Length
20 cm
Connector
20 pin DisplayPort - male
15 pin HD D-Sub (HD-15) - female
DisplayPort 1.1
