C2G 2-Port HDMI Auto Switch
Quicklinx: 9MR7WS00 Mfr#: 89050
This 2-port HDMI switch allows you to conveniently switch between two HDMI source devices on a single HDMI-enabled display supporting high definition video up to a 1080p resolution. In situations where a display does not have enough HDMI inputs to accommodate multiple source devices, this switch provides additional high-definition digital inputs and is compatible with HDMI-equipped devices such as Blu-ray and DVD players, high-definition satellite boxes and gaming consoles, including Sony PlayStation 4 (PS4) and Xbox ONE. The auto-switching functionality detects when a new device is connected or powered on and will automatically switch to that port. When the device in use is disconnected or powered off, it will switch to the device that was connected first. Alternatively, manual-switching functionality is available for situations where more control is desired – simply use the select button on top of the switch to switch back and forth between the two inputs. The power required for operation of this switch is provided from the HDMI source devices, so no separate power adapter is required.
  • Efficient compatibility
    Designed to seamlessly integrate with PC systems, this 2-Port HDMI Auto Switch offers a straightforward solution for users looking to enhance their multimedia setup without the hassle of manual adjustments.
  • High-definition support
    Supports 1080p resolution with a V-Sync rate of 60 Hz, ensuring a high-quality video experience that brings your content to life with vivid detail and clarity.
  • Optimal performance
    Operates within a wide range of environmental parameters, including operating temperatures from 5°C to 40°C and humidity levels from 10% to 90% (non-condensing), making it a reliable choice under various conditions.
C2G 2-Port HDMI Auto Switch - video/audio switch - 2 ports
Video/audio switch - 2 ports
Subtype
HDMI
Ports
2 x HDMI
8.6 cm x 4.4 cm x 1.6 cm
1-year warranty
Enclosure Type
Desktop
Subtype
HDMI
Ports
2 x HDMI
Max Resolution
1920 x 1080 / 1080p @ 60 Hz
2 x HDMI input , 1 x HDMI output
8.6 cm
4.4 cm
1.6 cm
Limited warranty - 1 year
5 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
64 °C
Humidity Range Storage
