The USB A Male to Lightning Male sync and charging cable is perfect for downloading data from or uploading data to the latest generation of Apple iPad, iPhone or iPod devices while also allowing the device to be charged. The cable construction and design make it ideal for travel. This cable is great as a replacement or a spare to sync and charge an Apple device at home, in the office or on the go. This cable is MFi certified for compatibility with Apple products.
- C2G USB A Male to Lightning Male Sync and Charging Cable - Lightning cable - Lightning / USB - 1 m
- Cable
- Length
- 1 m
- White
- Connector
- Lightning - male
- Connector (Second End)
- USB - male
- Sync and charge
- Limited lifetime warranty
- Cable Type
- Lightning cable
- Interface Supported
- Lightning / USB
- Jacket Material
- PVC
- Impedance
- 100 Ohm
- Length
- 1 m
- Plated Connector
- Nickel
- Sync and charge
- White
- Connector
- Apple Lightning - male
- 4 pin USB Type A - male
- MFI
- Limited warranty - lifetime
