C2G 1m USB A Male to Lightning Male Sync and Charging Cable
Quicklinx: 9Y4XWS00 Mfr#: 86051
Colours:
The USB A Male to Lightning Male sync and charging cable is perfect for downloading data from or uploading data to the latest generation of Apple iPad, iPhone or iPod devices while also allowing the device to be charged. The cable construction and design make it ideal for travel. This cable is great as a replacement or a spare to sync and charge an Apple device at home, in the office or on the go. This cable is MFi certified for compatibility with Apple products.
  • Connector 1
    (1) USB-A Male
  • Connector 2
    (1) Lightning Male
  • Colour
    White
  • Warranty
    Lifetime
C2G USB A Male to Lightning Male Sync and Charging Cable - Lightning cable - Lightning / USB - 1 m
Cable
Length
1 m
White
Connector
Lightning - male
Connector (Second End)
USB - male
Sync and charge
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Jacket Material
PVC
Impedance
100 Ohm
Length
1 m
Plated Connector
Nickel
Sync and charge
White
Connector
Apple Lightning - male
4 pin USB Type A - male
MFI
Limited warranty - lifetime
