C2G 1m USB 3.1 Gen 2 USB C Cable M/M - 4K support
Quicklinx: DWR7WS00 Mfr#: 88848
Length: 1m
£8.96 ex VAT
£10.75 inc VAT
This USB-C M/M Cable is the perfect solution for connecting two USB-C or Thunderbolt 3 enabled devices, such as a laptop, smartphone or tablet for high-speed data transfer, 4K video support, high bit depth audio and enhanced power delivery capabilities. Whether you’re desk-based or on-the-road, this lightweight, portable one-cable solution ensures that your USB-C equipped device is fully charged and ready to go with the 3A charging output, whilst simultaneously transferring photos, music or data at speeds up to 10Gbps. Stream video and audio with full DisplayPort 2.1 and Alt mode functionality, displaying up to 4K video with amazing contrast and colour depth to see photos, videos, and text with unbelievable detail. 4-channel audio with microphone support ensures crisp, lifelike audio delivery. With its robust design, the USB-C connector can be plugged in and un-plugged up to 10,000 times; six times more than a standard USB A Connector. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port.
  • Efficient charging and syncing
    Equipped with bare copper conductors, this 1 m USB Type-C Cable supports efficient charging and syncing, ensuring your devices stay connected and powered up without missing a beat.
  • High-quality connectivity
    Featuring nickel-plated connectors and a tinned copper braid shielding, this cable provides reliable, high-quality connections for all your USB-C devices, minimizing interference and signal loss.
  • Versatile compatibility
    Compliant with USB 3.1 Gen 2 and Thunderbolt 3 standards, the cable offers versatile compatibility with a wide range of devices, supporting 4K video output and high-speed data transfer for a seamless user experience.
C2G 1m USB Type C Cable - 4K support - USB 3.1 (Gen 2) M/M - USB C Cable - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
USB-C cable
Sync and charge, bare copper conductor
Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
USB 3.1 Gen 2 / Thunderbolt 3
3-year warranty
USB-C cable
Shielding Material
Tinned copper braid
Plated Connector
Nickel
Length
1 m
36 g
Connector
24 pin USB-C - male
24 pin USB-C - male
USB 3.1 Gen 2 / Thunderbolt 3, USB-IF
3-year warranty
Length: 1m
Brand: C2G
