This USB 3.0 (USB 3.1 Gen 1) USB-C to USB-Micro B cable is the perfect solution for connecting a smartphone, tablet, or other device that has a USB-Micro B port to a computer, tablet or other device that has a USB Type-C port up to 1 metre away for USB 3.0 (USB 3.1 Gen 1) communication. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 3.0 (USB 3.1 Gen 1) cable and differentiated from other cables which may support a different feature set. With its robust design, the USB-C connector can be plugged in and un-plugged up to 10,000 times; six times more than a standard USB A Connector. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. This cable supports a data rate up to 5Gbps for data transfer and sync with 5 volts and 1 amp of power for device operation and charging.
Efficient charging and syncing
This USB-C to Micro-USB cable supports both sync and charge functionality, making it a versatile choice for managing your devices. With the ability to handle USB 3.1 Gen 1 speeds, it ensures efficient data transfer and charging capabilities. -
Durable design
Featuring color-coded connectors and a nickel-plated shell, this cable is not only easy to connect but also offers enhanced durability. The gold-plated connector further ensures a reliable connection and superior performance over time. -
Universal compatibility
Designed to be compatible with PCs, this cable offers a wide range of use cases. Whether you're connecting devices for charging or data transfer, its universal compatibility ensures seamless integration with your existing setup.
- C2G 1m USB 3.1 Gen 1 USB Type C to USB Micro B Cable - USB C Cable Black - USB-C cable - 24 pin USB-C to Micro-USB Type B - 1 m
- USB-C cable
- Sync and charge, colour-coded connectors, nickel plated shell
- Length
- 1 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 10 pin Micro-USB Type B - male
- USB 3.0/ USB 3.1
- Black
- Limited lifetime warranty
- USB-C cable
- American Wire Gauge (AWG)
- 24/30
- Plated Connector
- Gold
- Length
- 1 m
- Black
- Connector
- USB 3.0/ USB 3.1
