This USB 2.0 USB-C to USB-Mini B cable is the perfect solution for connecting a camera, smartphone, tablet or other device that has a USB Mini B port to a computer, tablet or other device that has a USB Type-C port up to 1 metre away for USB 2.0 communication. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 2.0 cable and differentiated from other cables which may support a different feature set. With its robust design, the USB-C connector can be plugged in and un-plugged up to 10,000 times; six times more than a standard USB A Connector. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. This cable supports a data rate up to 480Mbps for data transfer and sync with 5 volts and 1 amp of power for device operation and charging.
Efficient charging and syncing
This USB-C to Mini USB-B cable is designed to facilitate quick and efficient charging, as well as high-speed data transfers. With its 24/30 American Wire Gauge (AWG), it ensures reliable connectivity and performance for syncing your devices. -
Durable design
Featuring color-coded connectors, a nickel-plated shell, and a gold-plated connector, this cable is built for durability and a long lifespan. The robust construction minimizes wear and tear, ensuring that the cable remains functional over time. -
Universal compatibility
Designed to be compatible with PCs, this cable supports a wide range of devices. Whether you're connecting to a device with a mini-USB Type-B port or a 24 pin USB-C port, this cable ensures seamless connectivity.
- C2G 1m USB 2.0 USB Type C to USB Mini B Cable M/M - USB C Cable Black - USB-C cable - mini-USB Type B to 24 pin USB-C - 1 m
- USB-C cable
- Sync and charge, colour-coded connectors, nickel plated shell
- Length
- 1 m
- Connector
- Mini-USB Type B - male
- Connector (Second End)
- 24 pin USB-C - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB-C cable
- American Wire Gauge (AWG)
- 24/30
- Plated Connector
- Gold
- Length
- 1 m
- Black
- Connector
- USB / USB 2.0
