C2G 1m USB 2.0 USB C to USB Mini B Cable M/M - Black
Quicklinx: CHNPWS00 Mfr#: 88854
Length: 1m
£12.67 ex VAT
£15.20 inc VAT
This USB 2.0 USB-C to USB-Mini B cable is the perfect solution for connecting a camera, smartphone, tablet or other device that has a USB Mini B port to a computer, tablet or other device that has a USB Type-C port up to 1 metre away for USB 2.0 communication. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 2.0 cable and differentiated from other cables which may support a different feature set. With its robust design, the USB-C connector can be plugged in and un-plugged up to 10,000 times; six times more than a standard USB A Connector. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. This cable supports a data rate up to 480Mbps for data transfer and sync with 5 volts and 1 amp of power for device operation and charging.
  • Efficient charging and syncing
    This USB-C to Mini USB-B cable is designed to facilitate quick and efficient charging, as well as high-speed data transfers. With its 24/30 American Wire Gauge (AWG), it ensures reliable connectivity and performance for syncing your devices.
  • Durable design
    Featuring color-coded connectors, a nickel-plated shell, and a gold-plated connector, this cable is built for durability and a long lifespan. The robust construction minimizes wear and tear, ensuring that the cable remains functional over time.
  • Universal compatibility
    Designed to be compatible with PCs, this cable supports a wide range of devices. Whether you're connecting to a device with a mini-USB Type-B port or a 24 pin USB-C port, this cable ensures seamless connectivity.
C2G 1m USB 2.0 USB Type C to USB Mini B Cable M/M - USB C Cable Black - USB-C cable - mini-USB Type B to 24 pin USB-C - 1 m
USB-C cable
Sync and charge, colour-coded connectors, nickel plated shell
Length
1 m
Connector
Mini-USB Type B - male
Connector (Second End)
24 pin USB-C - male
USB / USB 2.0
USB-C cable
24/30
Plated Connector
Gold
Length
1 m
Connector
24 pin USB-C - male
USB / USB 2.0
Length: 1m
Brand: C2G
