C2G 1m USB 2.0 USB C to USB Micro B Cable M/M - Black
Quicklinx: CHNHWS00 Mfr#: 88850
Length: 1m
£12.14 ex VAT
£14.56 inc VAT
This USB 2.0 USB-C to USB-Micro B cable is the perfect solution for connecting a smartphone, tablet, or other device that has a USB-Micro B port to a computer, tablet or other device that has a USB Type-C port up to 1 metre away for USB 2.0 communication. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 2.0 cable and differentiated from other cables which may support a different feature set. With its robust design, the USB-C connector can be plugged in and un-plugged up to 10,000 times; six times more than a standard USB A Connector. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. This cable supports a data rate up to 480Mbps for data transfer and sync with 5 volts and 1 amp of power for device operation and charging Note: This cable is designed to support USB 2.0 communication and features and is not able to support USB 3.1 Gen 2 Communication and features.
  • Efficient charging and syncing
    This USB-C to Micro-USB cable supports both sync and charge functionality, making it a versatile choice for connecting a wide range of devices. It handles data transfer and power delivery efficiently, ensuring reliable performance for daily needs.
  • Durable design
    Featuring color-coded connectors, a nickel-plated shell, and a gold-plated connector, this cable is built for durability. Its robust construction ensures a secure connection and offers enhanced resistance to wear and tear, providing peace of mind.
  • Universal compatibility
    Meeting the USB 2.0 standard, this cable is compatible with devices that support USB-C and Micro-USB connections. It allows for a seamless connection to a PC or other devices without the need for multiple cables.
C2G 1m USB 2.0 USB Type C to USB Micro B Cable M/M - USB C Cable Black - USB-C cable - Micro-USB Type B to 24 pin USB-C - 1 m
USB-C cable
Sync and charge, colour-coded connectors, nickel plated shell
Length
1 m
Connector
5 pin Micro-USB Type B - male
Connector (Second End)
24 pin USB-C - male
USB / USB 2.0
USB-C cable
American Wire Gauge (AWG)
24/30
Plated Connector
Gold
Length
1 m
Connector
24 pin USB-C - male
USB / USB 2.0
Length: 1m
Brand: C2G
