C2G 1m USB 2.0 USB C to USB B Cable M/M - Black
Quicklinx: CHNXWS00 Mfr#: 88858
Select:
  • 1m
This USB 2.0 USB-C to USB-B cable is the perfect solution for connecting a printer, hub, or other device that has a USB B port to a computer, tablet or other device that has a USB Type-C port up to 1 metre away for USB 2.0 communication. This cable supports a data rate up to 480Mbps for data transfer and sync with 5 volts and 1 amp of power for device operation and charging. With its robust design, the USB-C connector can be plugged in and un-plugged up to 10,000 times; six times more than a standard USB A Connector. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 2.0 cable and differentiated from other cables which may support a different feature set. This cable is designed to support USB 2.0 communication and features and is not able to support USB 3.1 Gen 2 communication and features.
  • Efficient charging and syncing
    The C2G 1m USB 2.0 USB Type C to USB B Cable M/M facilitates quick and efficient charging along with seamless data syncing capabilities. Its design ensures that your devices are always ready to use, making it an essential accessory for your connectivity needs.
  • Durable design
    Featuring a double-shielded structure with a nickel-plated shell and gold-plated connectors, this USB C cable is built for durability. The color-coded connectors make it easy to identify and use, ensuring a long-lasting and reliable connection between your devices.
  • Universal compatibility
    Designed to be compatible with PC, this cable supports a wide range of devices. Whether you're connecting to a printer, external hard drive, or any device with a USB Type-B port, this cable ensures a stable and secure connection.
C2G 1m USB 2.0 USB Type C to USB B Cable M/M - USB C Cable Black - USB-C cable - USB Type B to 24 pin USB-C - 1 m
USB-C cable
Double shielded
Sync and charge, colour-coded connectors, nickel plated shell
Length
1 m
Connector
4 pin USB Type B - male
Connector (Second End)
24 pin USB-C - male
USB / USB 2.0
USB-C cable
Double shielded
American Wire Gauge (AWG)
24/30
Plated Connector
Gold
Length
1 m
Connector
24 pin USB-C - male
USB / USB 2.0
