C2G 1m USB 2.0 A Right Angle Male to Micro-USB Right Angle Male
Quicklinx: 9Y4LWS00 Mfr#: 81704
Connect to mobile phones, GPS systems, PDAs, OTG devices and digital cameras by using the micro-USB connection on your computer or other USB device. The micro-USB connector is smaller and thinner than the previous USB Mini-b standard while offering better performance. Its small right angle form factor is ideal for today's compact portable devices while easily transferring data or charging your device at a transfer speed up to 480 Mbps. This cable is compliant with USB 2.0 specifications and the On-The-Go supplement.
  • Efficient syncing
    The USB 2.0 A Right Angle to Micro-USB B Right Angle Cable facilitates quick and efficient data transfer, ensuring your devices stay synced and up to date with ease.
  • Enhanced durability
    Designed with right angle connectors on both ends, this cable offers enhanced durability and reduces strain on the connection points, making it ideal for tight spaces and preventing cable damage.
  • Versatile connectivity
    Featuring a 5-pin Micro-USB Type-B at one end and a 4-pin USB Type-A at the other, this cable supports a wide range of devices, from smartphones to tablets, providing reliable sync and charge functionality.
C2G USB 2.0 A Right Angle to Micro-USB B Right Angle Cable - USB cable - Micro-USB Type B to USB - 1 m
USB cable
90° connector, right-angled connector, sync and charge, USB On-The-Go
Length
1 m
Connector
5 pin Micro-USB Type B - male
Connector (Second End)
4 pin USB Type A - male
USB cable
Length
1 m
Connector
