Product
C2G 1m Thunderbolt 3V Cable (20GBPS) 1m
Quicklinx: D6TTWS00 Mfr#: 88838
Length: 1m
12 in stock
£28.70 ex VAT
£34.44 inc VAT
Standard delivery Delivered within 3-5 working days
Thunderbolt 3 brings lightning speed data transfer, 4K video support, high bit depth audio, and power delivery up to 100W. Get more done with less hassle by carrying one cable to complete nearly any task. Deliver up to 20Gbps to or from a Thunderbolt 3 enabled port. Whether uploading or downloading data, this cable is an ideal solution to transfer large amounts of information such as high resolution photos for editing or storage, 3D models for video game authoring, or HD video for editing. Ensure that a Thunderbolt 3 equipped laptop, smartphone, or tablet is fully charged and ready to go while displaying video content, transferring files, or streaming audio. Deliver up to 100W of charging power to or from the connected device with smart power delivery. The Thunderbolt 3 cable offers a light-weight, portable, and simple way to deliver video, and data—while staying charged up! The USB-C connector has a robust design, allowing for the connector to be plugged in and un-plugged up to 10,000 times. The sturdy construction ensures that the product provides peace of mind and is built to stand up to the rigors the most demanding on-the-go life. The USB-C connector has a symmetrical design which is identical on both sides, so it does not matter if you plug it in upside-down or right-side-up. It will plug in the first time, every time while preventing damage to the connector port.
  • Colour
  • Warranty
    3 years
  • Connector 1
    USB-C Male
  • Connector 2
    USB-C Male
C2G 1M Thunderbolt 3 cable (20Gbps) - Thunderbolt cable - 1 m
Thunderbolt cable
4K support, sync and charge
Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Rated Voltage
30 V
Thunderbolt 3
3 years warranty
Thunderbolt cable
American Wire Gauge (AWG)
30
Rated Voltage
30 V
Length
1 m
52.6 g
Connector
24 pin USB-C - male
24 pin USB-C - male
Thunderbolt 3
3 years warranty
Length: 1m
Brand: C2G
Price Range Ex VAT: 0 - 50
