C2G 1m SC/SC LSZH 62.5/125 Fibre
Quicklinx: 6C16WS00 Mfr#: 85239
With SC to SC termination, this high quality fibre optic patch cable is specifically designed for Fast Ethernet, fibre channel, ATM and Gigabit Ethernet applications. The SC connector features a push-pull locking system. The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures. This reduces the amount of harmful toxic and corrosive gases that cabling made with plastic materials would otherwise emit into the air during combustion. This construction makes LSZH cables ideal for use where the protection of people and equipment from harmful corrosive gases is absolutely critical. The patented injection moulding process provides each connection greater durability in resisting pulls, strains and impacts from cabling installs.
  • Warranty Details
    This product carries a lifetime warranty
  • Jacket Rating
  • Connector Durability
C2G Low-Smoke Zero-Halogen - patch cable - 1 m - orange
Patch cable
Fibre optic
Type of Fibre Optics
Multimode
Length
1 m
Core / Cladding Diameter
62.5 / 125 micron
Connector
2 x SC multi-mode - male
Connector (Second End)
Orange
Network Cable Type
Patch cable
Fibre optic
Multimode
Jacket Material
Low Smoke Zero Halogen (LSZH)
Fibre Qty
2
62.5 / 125 micron
Length
1 m
Orange
Connector
RoHS
