Gain maximum flexibility when positioning your monitor with Premium Shielded VGA Cables from C2G. Constructed from premium grade shielded video cable, these cables use a combination of coax and twisted-pair to accommodate cable runs up to 30.48 meters away, without any of the typical distortion problems associated with extended length cabling runs. These cables are designed to hold the signal over greater distances without the need for boosting or reconditioning. These premium SXGA monitor extension cables are ideal for video presentations, classroom environments, POS, server rooms or for organizing your work area for maximum comfort and efficiency.
- C2G Premium VGA cable - 1 m
- VGA cable
- Technology
- Shielded
- Length
- 1 m
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- RoHS
- VGA cable
- Technology
- Shielded
- Length
- 1 m
- Connector
- 15 pin HD D-Sub (HD-15) - male
- RoHS
