C2G 1m Mini DisplayPort Male to Single Link DVI-D Male Adapter Cable - White
Quicklinx: 9MS0WS00 Mfr#: 84337
Select:
  • 1m
This adapter cable is an ideal solution for connecting the Mini DisplayPort output of a small laptop or tablet to a computer monitor which accepts a DVI-D input. This cable carries a digital video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
  • Seamless connectivity
    Designed to bridge the gap between your Mini DisplayPort and DVI-D devices, this 1 m adapter cable offers a male Mini DisplayPort connector on one end and a male 18+1 pin digital DVI (Single-Link) connector on the other, ensuring a seamless connection and optimal video quality.
  • High compatibility
    With its compatibility focused on PC, this adapter cable is engineered to connect and work flawlessly with your computer systems, enhancing your experience without the need for additional drivers or software.
C2G 1m Mini DisplayPort to Single Link DVI-D Adapter Cable M/M - Mini DP to DVI - White - DisplayPort cable - 1 m
DisplayPort cable - single link
Length
1 m
Connector
Mini DisplayPort - male
Connector (Second End)
DVI-D - male
White
DisplayPort cable
TMDS Links
Single link
Length
1 m
White
Connector
18+1 pin digital DVI (Single-Link) - male
